How to Remove Stickers From a Car
Выберете то, что вам нужно
  1. How to Remove Stickers From a Car, How to Remove Stickers From a Car: шаг 1, изображение 1 из 1
    • First of all, find the area where the sticker is. In my case, it is on the car body near the fuel tank.
  2. How to Remove Stickers From a Car: шаг 2, изображение 1 из 2 How to Remove Stickers From a Car: шаг 2, изображение 2 из 2
    • Spray the area with some soap water or with cleaning sprays. Goo gone work really well for this and might allow you to skip the blow dryer in the next step.
  3. How to Remove Stickers From a Car: шаг 3, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Microfiber Cleaning Cloths
    $3.99
    Купить
    • Next, wipe the area thoroughly with a microfiber cleaning cloth. Skip this step if you're using Goo Gone.
  4. How to Remove Stickers From a Car: шаг 4, изображение 1 из 2 How to Remove Stickers From a Car: шаг 4, изображение 2 из 2
    • Turn on the hairdryer and put it in its hot setting.
    • Start heating the sticker from a few inches away. Try to heat the sticker from the center outward.
    • This will soften the adhesive under the sticker and make the following steps much easier.
    • Using Goo Gone might allow you to skip this step, but for stubborn stickers, the hair dryer + Goo Gone will be most effective.
  5. How to Remove Stickers From a Car: шаг 5, изображение 1 из 3 How to Remove Stickers From a Car: шаг 5, изображение 2 из 3 How to Remove Stickers From a Car: шаг 5, изображение 3 из 3
    Plastic Cards
    $2.99
    Купить
    • Use a plastic card and try to scrape the sticker from the edges.
    • A plastic card can help you remove your unwanted stickers without damaging the paint.
    • If it doesn't work, try to repeat step 4 and then try again.
    • If you are working on a glass surface, use a razor blade instead of a plastic card! It may seem too much for the glass, but the glass is hard enough to use a razor blade on.
    • Be careful when using a razor blade!
  6. How to Remove Stickers From a Car: шаг 6, изображение 1 из 2 How to Remove Stickers From a Car: шаг 6, изображение 2 из 2
    • Finally, if there is any residue, heat the residue with the hairdryer and scrape it off with a plastic card or razor blade (depending on where the sticker is). Using Goo Gone makes removing any residue easy.
    • After removing all stickers and residue, use some detailing spray or cleaning spray to clean the area again and you are all set!
Заключение
After these steps, you should have a clean surface without any residues!
Xuanfang Gao
Участник с: 09/15/21
141 Репутация
1 руководство автора
Команда
York University, Team E-7, Melo-Thaiss Fall 2021 Участник York University, Team E-7, Melo-Thaiss Fall 2021
YORK-MELO-THAISS-F21SEG7
1 член
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 33
За всё время: 720
