Linksys WRT54GS v2 Antenna Ports Replacement
Выберете то, что вам нужно
  1. Linksys WRT54GS v2 Antenna Ports Replacement, Front Case: шаг 1, изображение 1 из 1
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Antenna Ports Replacement: шаг 2, изображение 1 из 1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Antenna Ports Replacement: шаг 3, изображение 1 из 1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Antenna Ports Replacement: шаг 4, изображение 1 из 1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
  5. Linksys WRT54GS v2 Antenna Ports Replacement, Motherboard: шаг 5, изображение 1 из 1
    • Slide the board unit out and up.
  6. Linksys WRT54GS v2 Antenna Ports Replacement: шаг 6, изображение 1 из 1
    • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
    • Slide the back cover out and away from the circuit board.
  7. Linksys WRT54GS v2 Antenna Ports Replacement, Antenna Ports: шаг 7, изображение 1 из 2 Linksys WRT54GS v2 Antenna Ports Replacement, Antenna Ports: шаг 7, изображение 2 из 2
    • Turn the circuit board over and identify which solder connection you will desolder.
    • The solder connections shown in red hold the right antenna port in place. There is one more attachment for this antenna on the other side of the board.
    • The solder connections shown in blue hold the left antenna port in place. Desolder these 4 points to remove the antenna port.
  8. Linksys WRT54GS v2 Antenna Ports Replacement: шаг 8, изображение 1 из 1
    • Turn on your soldering iron and allow it to get to its highest temperature setting (minimum 600ºF).
  9. Linksys WRT54GS v2 Antenna Ports Replacement: шаг 9, изображение 1 из 1
Заключение
2 участников успешно повторили данное руководство.
Allian Roman
Участник с: 10/12/11
276 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 3-4, Regan Fall 2011 Участник Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 членов
Автор 12 руководств
Один комментарий
Most do not have removeable antennae ports
tom - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 13
За всё время: 3,254
