Lenovo ThinkPad X1 Carbon 6th Gen Battery Replacement
Выберете то, что вам нужно
  1. Lenovo ThinkPad X1 Carbon 6th Gen Battery Replacement, Back Cover: шаг 1, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 6th Gen Battery Replacement, Back Cover: шаг 1, изображение 2 из 2
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen Battery Replacement: шаг 2, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 6th Gen Battery Replacement: шаг 2, изображение 2 из 2
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon 6th Gen Battery Replacement, Battery: шаг 3, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 6th Gen Battery Replacement, Battery: шаг 3, изображение 2 из 2
    • Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
  4. Lenovo ThinkPad X1 Carbon 6th Gen Battery Replacement: шаг 4, изображение 1 из 1
    • Take out the battery by lifting it from the bottom edge of the laptop, and then pulling away from the motherboard.
Заключение
19 участников успешно повторили данное руководство.
Michael Megna
Участник с: 01/23/20
1 277 Репутация
Автор 7 руководств
Команда
Cal Poly, Team S19-G4, White Winter 2020 Участник Cal Poly, Team S19-G4, White Winter 2020
CPSU-WHITE-W20S19G4
3 членов
Автор 22 руководств
7 Комментариев
Does it require to switch off battery in BIOS first?
Rafal Skolasinski - Ответить
My work wanted to e-waste my 3 year-old ThinkPad. Bought the replacement battery here, followed the instructions—it works fine now. Thanks a lot.
Ryan Phillips - Ответить
Great guide, and what an easy laptop to work on!!!
surfdaworld - Ответить
Step 4 is wrong.
You cannot pull the battery out on bottom edge because of the grey plastic arresting aids which you can see in the picture of step 3.
You first have to slide the battery as far as possible to the bottom edge into these grey parts so that the plug connection on top gets lose slightly and then carefully pull it out on side of the mainboard connector.
Also you do not need that Jimmy in step 2. After removing the screws just pull and lift the base cover with your fingers from the area where the hinges are located and then it easily slips out at the front.
Frank B. - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 20
За последние 7 дней: 186
За последние 30 дней: 744
За всё время: 39,174
