Nintendo 3DS XL Battery Replacement
Выберете то, что вам нужно
  1. Nintendo 3DS XL Battery Replacement, Battery: шаг 1, изображение 1 из 2 Nintendo 3DS XL Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Loosen the two #0 Phillips 4.2 mm-length screws located at the top of the back cover.
    • The screws have locking washers that prevent the screws from falling off of the back cover. Leave these locking washers on the screws; it is not necessary to remove the washers for this repair guide.
  2. Nintendo 3DS XL Battery Replacement: шаг 2, изображение 1 из 2 Nintendo 3DS XL Battery Replacement: шаг 2, изображение 2 из 2
    • Hold the device so that the cover is facing up.
    • Using a plastic opening tool, pry off the cover starting at the top right corner.
    • Hold the edge of the cover to ensure it does not reattach.
    • Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
    • Take off the cover of the device and set it aside.
  3. Nintendo 3DS XL Battery Replacement: шаг 3, изображение 1 из 3 Nintendo 3DS XL Battery Replacement: шаг 3, изображение 2 из 3 Nintendo 3DS XL Battery Replacement: шаг 3, изображение 3 из 3
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry off the battery from the lower casing.
    • Lift the battery out of the case and set aside.
Заключение
42 участников успешно повторили данное руководство.
Charlene Donlon
Участник с: 04/08/14
10 271 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 9-13, Regan Spring 2014 Участник Cal Poly, Team 9-13, Regan Spring 2014
CPSU-REGAN-S14S9G13
5 членов
Автор 44 руководств
5 Комментариев
Time estimate: 3 - 9 hours Difficulty: Very difficult ??????
More like 30-90 seconds, and that's if you have to search for a screwdriver.
Tommy Lynch - Ответить
机器无法开机怎么办?是电池的问题吗?
doanaruto - Ответить
It should be noted that the bottom three clips on the bottom of the backplate can’t just be snapped in, they need to be slipped in, so when removing the backplate, it should be tiled away from the system and then pulled up from the bottom, and those three clips on the bottom should be the first clips in when you’re putting it back together, sliding them in with the backplate at an angle, and then the rest of the clips just snap in.
Cole Jackson - Ответить
Just did this. For reasmbly I recommend putting the bottom/lower part of the case on first before you screw it back on.
Scott Vogel - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 24
За последние 7 дней: 187
За последние 30 дней: 850
За всё время: 50,710
