Введение
Use this guide to remove or replace the power (or sleep/wake) button cover in your iPhone 6s. This guide is just for the physical button, and not the electronic switch beneath.
If you need to replace the power button control cable or electronics, follow this guide.
Выберете то, что вам нужно
Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
Инструмент, используемый на этом этапе:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forwards to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next three steps.
If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Apply a suction cup to the lower left corner of the display assembly.
Take care not to place the suction cup over the home button.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Place the flat edge of a spudger into the gap between the screen and rear case, directly above the headphone jack.
Twist the spudger to widen the gap between the front panel assembly and the rest of the phone.
Insert the flat end of the spudger on the left side of the phone, between the display assembly and rear case.
Slide the spudger up the side of the phone to separate the adhesive and pop the clips free.
Remove the spudger and reinsert it on the bottom edge, where you pried the phone open.
Slide the spudger to the right, along the bottom edge of the phone.
Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone.
Pull up on the nub on the top side of the suction cup to remove it from the front panel.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Remove two Phillips screws securing the battery connector bracket, of the following lengths:
One 2.9 mm screw
One 2.2 mm screw
Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
Remove the following four Phillips screws securing the display cable bracket:
Three 1.2 mm screws
One 2.8 mm screw
Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board.
Disconnect the digitizer cable by prying it straight up from its socket on the logic board.
Disconnect the display cable by prying it straight up from its socket on the logic board.
Use the flat end of a spudger to disconnect the rear camera from its socket on the logic board.
Remove the following two Phillips screws over the rear camera bracket:
One 1.6 mm screw
One 2.0 mm screw
Insert a spudger to the side of the camera, between the rear case and the camera module.
Gently pry up on the camera to nudge it out from its housing.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Remove the two 2.3 mm Phillips screws securing the upper component cable connector bracket.
Remove the following five Phillips screws securing the top left Wi-Fi antenna:
Two 1.5mm screws
One 2.3 mm screw
One 1.9 mm screw
One 2.0 mm screw
Use the flat end of a spudger to disconnect the audio control cable from its socket on the logic board.
Use the pointed tip of a spudger to disconnect the antenna cable from its socket on the upper right corner of the logic board.
Use the pointed tip of a spudger to disconnect the antenna cable from its socket on the lower left corner of the logic board.
Insert the flat end of a spudger underneath the Lightning connector ribbon cable. Lift up to disconnect it from its socket on the logic board.
Gently pull up on the antenna cable to de-route it from the two clips on the right side of the logic board.
Remove the following two Phillips screws:
One 2.5 mm screw at the top of the logic board
One 1.4 mm screw set into the upper edge of the rear case
Remove the final three screws securing the logic board to the rear case:
One 1.9 mm Phillips screw
One 2.5 mm hex nut
One 1.8 mm Phillips screw
Insert an opening pick below the lower edge of the logic board, between the board and the loudspeaker.
Use the opening pick to gently lift the logic board out of its housing.
Remove the logic board.
Remove the two 1.5 mm Phillips screws holding the Taptic Engine in place.
Remove the Taptic Engine.
Pull one of the adhesive strips straight out, towards the bottom of the iPhone.
For best results, pull the strip at a 60º angle or less.
Continue pulling until the strip is fully removed.
If one of the adhesive strips breaks under the battery during this procedure, and cannot be retrieved, remove the remaining strip, and then skip to Step 48.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
If you successfully removed all three adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
After about a minute, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
Remove the single 1.3 mm Phillips screw securing the flash bracket.
Remove the flash bracket.
Use the flat end of a spudger to lift the flash out of its housing in the rear case.
Remove the following five Phillips screws:
Two 2.5 mm screws set into the left edge of the rear case
One 2.1 mm Phillips #000 screw set into the left edge of the rear case
Two 2.1 mm screws set into the right edge of the rear case
Use the pointed tip of a spudger to gently separate the microphone from the rear case.
Slide an opening pick between the upper component cable and the rear case.
Gently separate the cable from the rear case.
Continue pushing the opening pick under the cable until it fully separates from the rear case.
If your replacement part did not come with the mute switch cover, you will need to remove the switch cover and transfer It.
Use the flat end of the spudger to press down and hold the old bracket firmly in place.
Use tweezers or your fingers to carefully rock the switch cover such that the switch cover pins swing out of their clips.
Lift the switch cover straight up.
Grasp the metal bar on the back of the power button cover.
Remove the power button cover.
33 участников успешно повторили данное руководство.
