Dyson DC24 Ball Lower Small Bearing Replacement
Выберете то, что вам нужно
  1. Dyson DC24 Ball Lower Small Bearing Replacement, DC24 Ball's Lower Small Bearing: шаг 1, изображение 1 из 1
    • Recline vacuum all the way to expose as much of the ball as possible.
  2. Dyson DC24 Ball Lower Small Bearing Replacement: шаг 2, изображение 1 из 1
    • Using a Torx screwdriver, remove the four screws that hold both sides of the ball together.
  3. Dyson DC24 Ball Lower Small Bearing Replacement: шаг 3, изображение 1 из 1
    • Remove the end of the lower duct hose to reveal a torx screw.
    • Remove the screw that holds the motor to the axel.
  4. Dyson DC24 Ball Lower Small Bearing Replacement: шаг 4, изображение 1 из 2 Dyson DC24 Ball Lower Small Bearing Replacement: шаг 4, изображение 2 из 2
    • Remove the three torx screws on the otherside.
    • Then remove the cover which will reveal some power cables.
    • Then remove the last screw that holds the motor to the axel.
  5. Dyson DC24 Ball Lower Small Bearing Replacement: шаг 5, изображение 1 из 1
    • Remove the post motor filter.
    • Carefully pull the axel out of its hole and down.
  6. Dyson DC24 Ball Lower Small Bearing Replacement: шаг 6, изображение 1 из 2 Dyson DC24 Ball Lower Small Bearing Replacement: шаг 6, изображение 2 из 2
    • Place the new bearing on the axel. (It doesn't matter which way it goes on)
  7. Dyson DC24 Ball Lower Small Bearing Replacement: шаг 7, изображение 1 из 2 Dyson DC24 Ball Lower Small Bearing Replacement: шаг 7, изображение 2 из 2
    • When reassembling, it is easiest to put the vacuum in its upright position to insert the axel screws.
    • The red arrow points to the type of torx screws that hold the motor in place while the orange arrow points to the type that hold the orange ball together.
Заключение
2 участников успешно повторили данное руководство.
ForumHermit
Участник с: 08/16/13
1 730 Репутация
Автор 2 руководств
4 Комментариев
When replacing the bearings, is there only one small bearing set to replace or are there two sets, one on each side? If there are two, should they both be replaced?
Josh McCanless - Ответить
I believe there is only one you need to replace. This was a common issue with the DC24.
ForumHermit -
Thanks for the guide. $20 for the part and 20 minutes later, I saved myself $400.
You, sir, are awesome.
Bless you for the guide.
No worries! I made this guide to help people do that exact thing.
ForumHermit - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 24
За всё время: 5,411
