Laptop Ram/Memory Replacement
Выберете то, что вам нужно
  1. Laptop Ram/Memory Replacement, RAM door: шаг 1, изображение 1 из 3 Laptop Ram/Memory Replacement, RAM door: шаг 1, изображение 2 из 3 Laptop Ram/Memory Replacement, RAM door: шаг 1, изображение 3 из 3
    • Many laptops have a door for the ram. But often, removing the entire back cover is necessary.
    • Remove screws on Ram door.
    • There is now access to the ram.
    • Remember to always remove or disconnect the battery!
  2. Laptop Ram/Memory Replacement, Releasing the SODIMM: шаг 2, изображение 1 из 1
    • Push metal tab out of the way. Some laptops have screws instead of tabs.
  3. Laptop Ram/Memory Replacement, Removing the RAM: шаг 3, изображение 1 из 3 Laptop Ram/Memory Replacement, Removing the RAM: шаг 3, изображение 2 из 3 Laptop Ram/Memory Replacement, Removing the RAM: шаг 3, изображение 3 из 3
    • lift up on ram.
    • Pull out of SODIMM socket.
  4. Laptop Ram/Memory Replacement, Removing second stick: шаг 4, изображение 1 из 1
    • Repeat with second stick. Sometimes the second stick is layered under the first.
  5. Laptop Ram/Memory Replacement, Replacing the RAM: шаг 5, изображение 1 из 1
    • Remember, If only replacing one Stick, to put that stick in DIMM A or DIMM 1.
    • There are five types of laptop laptop ram: DDR, DDR2, DDR3, DDR3L, and DDR4.
    • Make sure that whatever ram your laptop was using is replaced by that same type. Memory is not cross compatible with desktop memory, so make sure that your RAM is SODIMM laptop memory. SODIMMs are usually about 3" long, while desktop DIMMs are about 4"-5" long.
  6. Laptop Ram/Memory Replacement, Putting the Memory Back: шаг 6, изображение 1 из 3 Laptop Ram/Memory Replacement, Putting the Memory Back: шаг 6, изображение 2 из 3 Laptop Ram/Memory Replacement, Putting the Memory Back: шаг 6, изображение 3 из 3
    • Re-insert RAM at a 45 degree angle and push down until clips snap into place or screw back in.
    • Make sure that pins line up correctly and memory is all the way in place.
    • This is incorrect.
    • Replace RAM door.
Финишная черта
11 участников успешно повторили данное руководство.
George A.
Участник с: 12/07/16
21 879 Репутация
Автор 4 руководств
Команда
Community Protectors Участник Community Protectors
Community
19 членов
Автор 24 руководств
2 Комментариев
Thank you! Your photographs and simple directions gave me the courage to try this. It’s kind of exhilarating to see those memory sticks pop up and then to hear them click in.
Christie Sonmez - Ответить
@curiousandcheap I'm glad I could help! It's really one of the simplest upgrades you can do as long as your laptop doesn't specifically block access to the RAM compartment, but most brands make a door like the one shown to make it easier.
George A. - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 11
За последние 7 дней: 85
За последние 30 дней: 362
За всё время: 24,194
