Выберете то, что вам нужно
Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
Remove the microSD card slot cover. Remove any microSD card (if inserted).
Using a Phillips head screwdriver, remove the three 0.75 mm screws.
Orient the device so the screen is facing you.
Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
Continue to detach the backplate from the frame by moving the spudger around the perimeter.
Remove the 3 screws in the auxiliary port cover and lift the plastic piece.
Carefully pull back the auxiliary module to move it out of the way.
Remove the plastic block in front of the hinge.
39 участников успешно повторили данное руководство.
17 Комментариев
Very good. Nice operation. For me it takes 10 minutes for get the battery out the device and 4 minutes to replace all. Thanks!!
Seem to be missing the step where you disconnect the battery. That seemed real important as I'm sitting here with the tablet in bits trying to see how to do that bit.
Matt, I just pulled mine apart and the problem might be that you have a different revision of your tablet. Mine had three screws on the backplate but one of them is next to, not in the sd card slot, and there were only 2 screws on the “aux port" (speaker for me) not three.
If so, I had to remove the camera module to get the battery cabling free, it is threaded through a shared camera/kickstand bracket that looks permanent. Removing the camera was creepy, it takes more force than I like, but doable:
Pull the camera wiring harness from the motherboard, unscrew, I'm my case, everything in that area, I have broken enough stuff because of missed screws. The camera itself has 2 screws holding it down via the same plate that the battery cable snakes through. After that it's just a lift/pry thing until the module pops out.
Wish I could put up some pictures but I don't see a way, hope this helps you or anyone else. This tablet is easier to get into then most, but it would be easy to fubar on this if not careful.
Hi, I have a problem with the battery of lenovo yoga tab 3 10.1 and need a replacement for it. Could any one please let me me know where I can get the battery?
I have the same problem. Where to find the battery for YOGA Tablet 3 PRO 10 YT3-X90F 32GB, ASIN B015MOQP02 on Amazon. Many thanks
