<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Heat Gun&quot;]]></title>
<link>https://ru.ifixit.com/Answers/Device/Heat_Gun?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Heat Gun&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Wed, 12 Aug 2026 20:55:10 -0700</pubDate>
<item>
<title><![CDATA[Drill Master Heat Gun: Is this heat gun safe to use on a phone?]]></title>
<description><![CDATA[<p>I was going to use this on a Samsung S8 Edge to melt the adhesive holding the back glass and screen on and just wanted to know if it was safe.  Thanks!</p>
<p>⟐ Answer accepted апреля 04, 2019 at 19:43 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/559621/Is+this+heat+gun+safe+to+use+on+a+phone</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/559621</guid>
<pubDate>Thu, 04 Apr 2019 19:43:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[Heat Gun: Works only on lower settings]]></title>
<description><![CDATA[<p>My B&amp;D KX1693 works fine on settings 1 &amp; 2 but when put on 3 nothing happens, the fan is not on and no heat produced.</p>
<p>Any ideas?</p>
<p>⟐ Answered сентября 17, 2023 at 1:48 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/814171/Works+only+on+lower+settings</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/814171</guid>
<pubDate>Sun, 17 Sep 2023 01:48:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Drill Master Heat Gun: device works, rattle inside. piece holding power cord in place broken]]></title>
<description><![CDATA[<p>Piece fell out. Do I have to replace ?</p>
<p>⟐ Answer edited декабря 18, 2022 at 18:14 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/760170/device+works,+rattle+inside.+piece+holding+power+cord+in+place+broken</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/760170</guid>
<pubDate>Sun, 18 Dec 2022 18:14:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Heat Gun: Why my heat gun stop and never been worked]]></title>
<description><![CDATA[<p>After using inco heat gun never been worked like no power</p>
<p>⟐ Answered января 29, 2026 at 3:31 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/872208/Why+my+heat+gun+stop+and+never+been+worked</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/872208</guid>
<pubDate>Thu, 29 Jan 2026 03:31:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Heat Gun: Nozzles for Heat Gun Black&Decker]]></title>
<description><![CDATA[<p>I want to use my Black&amp;Decker Hot Air Gun</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/KVahY5cKSTYHgBEP.standard" width="225" height="225" class="hasMenu hasLarge" alt="Изображение" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/KVahY5cKSTYHgBEP.full&quot;, '', 'width=474,height=474')" /></div>
<p>which is 1750 Watt with a range of 460 to 600 Celsius degrees (two-button controlled) for detaching very small components like SMD resistances, IC mircro-controllers etc, being on electronic boards like motherboards, cards and so on.</p>
<p>But its nozzle is very big for this purpose. It has a diameter of 30 mm, when some of these components have diameter of 1mm.</p>
<p>So i want to buy and use a nozzle adapter. I have found a set of five pieces that maybe can adapt in its physical nozzle (if not i will make some kind of patent to fix it).</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/yaPsJRSBjS3ouFS2.standard" width="225" height="225" class="hasMenu hasLarge" alt="Изображение" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/yaPsJRSBjS3ouFS2.full&quot;, '', 'width=1000,height=1000')" /></div>
<p>But the problem is that a friend told me that if the diameter of the nozzle become very small, then the air, that flow from inside to outside through the nozzle, will be blocked by the very small diameter and this can cause the overheating of the inside part of the gun so it may can cause its destruction, its burning.</p>
<p>Until now i am using an nozzle adapter with diameter of 15 mm, without a problem.</p>
<p>The adapters that i want to buy have diameters of 3mm, 6mm, 5mm, 8mm, 10mm.</p>
<p>Does anybody know something about this ?</p>
<p>Can i buy the nozzle adapters ?</p>
<p>Can i do something else ?</p>
<p>I know there are special tools for these purpose (electronics repairing hot air gun stations) but they are too expensive.</p>
<p>⟐ Commented сентября 05, 2023 at 6:38 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/811734/Nozzles+for+Heat+Gun+Black&amp;Decker</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/811734</guid>
<pubDate>Tue, 05 Sep 2023 06:38:26 -0700</pubDate>
</item>
<item>
<title><![CDATA[Heat Gun: I have a ingco HG200028 heat gun and the PCB SWITCH CONTROL IS BAD.]]></title>
<description><![CDATA[<p>I have a ingco HG200028 heat gun and the PCB SWITCH CONTROL IS BAD. How do I replace it</p>
<p>⟐ Answered января 29, 2026 at 7:41 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/938261/I+have+a+ingco+HG200028+heat+gun+and+the+PCB+SWITCH+CONTROL+IS+BAD.</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/938261</guid>
<pubDate>Thu, 29 Jan 2026 07:41:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[Heat Gun: Is it okay to use it at 220V?]]></title>
<description><![CDATA[<p>I bought this item</p>
<p>This item has a 120V specification but the place where I live supports 220V</p>
<p>Is it okay to use 220V?</p>
<p>⟐ Comment deleted июля 13, 2022 at 7:02 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/739941/Is+it+okay+to+use+it+at+220V</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/739941</guid>
<pubDate>Wed, 13 Jul 2022 07:02:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Drill Master Heat Gun: What is the black part on the line side of switch]]></title>
<description><![CDATA[<p>on the line side of the switch is what look like a resistor of some kind. The # on the item are in 5408 what is it . It’s black in color with a silver stripe.</p>
<p>⟐ Answer accepted октября 01, 2019 at 19:35 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/550031/What+is+the+black+part+on+the+line+side+of+switch</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/550031</guid>
<pubDate>Tue, 01 Oct 2019 19:35:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Heat Gun: Tại sao máy sấy nhiệt của tôi không hoạc động]]></title>
<description><![CDATA[<p>Máy sấy không hoạt</p>
<p>động được. Nguyên nhân tại sao</p>
<p>Translation Vietnamese - English</p>
<p>Why won't my heat dryer start</p>
<p>The dryer does not work</p>
<p>movable. Reasons why</p>
<p>⟐ Commented мая 05, 2026 at 9:33 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/953529/T%E1%BA%A1i+sao+m%C3%A1y+s%E1%BA%A5y+nhi%E1%BB%87t+c%E1%BB%A7a+t%C3%B4i+kh%C3%B4ng+ho%E1%BA%A1c+%C4%91%E1%BB%99ng</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/953529</guid>
<pubDate>Tue, 05 May 2026 09:33:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[Heat Gun: This blower no running]]></title>
<description><![CDATA[<p>This blower can not running</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/865091/This+blower+no+running</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/865091</guid>
<pubDate>Sat, 17 Aug 2024 01:52:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Heat Gun: My gun is not heating]]></title>
<description><![CDATA[<p>I'm not getting any heat but it blows warm air</p>
<p>⟐ Commented апреля 11, 2024 at 1:15 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/844484/My+gun+is+not+heating</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/844484</guid>
<pubDate>Thu, 11 Apr 2024 01:15:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Heat Gun: My heat gun setting 1 temp same as setting 2 temp it's overheating]]></title>
<description><![CDATA[<p>Over heating problem, my heat gun temp working same temperature 🤒 i want lower heat</p>
<p>⟐ Commented октября 03, 2023 at 3:12 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/817259/My+heat+gun+setting+1+temp+same+as+setting+2+temp+it&#039;s+overheating</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/817259</guid>
<pubDate>Tue, 03 Oct 2023 03:12:41 -0700</pubDate>
</item>
</channel>
</rss>
