<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Whirlpool Washing Machine&quot;]]></title>
<link>https://ru.ifixit.com/Answers/Device/Whirlpool_Washing_Machine/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Whirlpool Washing Machine&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Mon, 27 Jul 2026 00:15:50 -0700</pubDate>
<item>
<title><![CDATA[Whirlpool Washing Machine: Washer fills with water, doesn't agitate but will spin out water?]]></title>
<description><![CDATA[<p>Whirlpool Ultimate Care 2 Model</p>
<p>After the washer fills with water the washer begins to hums loudly. The washer then begins to smell as if something is getting hot. The only function that really works after this point is if the washer is turned to the spin out cycle. The washer can spin out all of the water.</p>
<p>What is wrong and can I fix it? Thank you in advance for any help.</p>
<p>⟐ Answer edited июля 26, 2026 at 20:17 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/154421/Washer+fills+with+water,+doesn&#039;t+agitate+but+will+spin+out+water</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/154421</guid>
<pubDate>Sun, 26 Jul 2026 20:17:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Washer fills, agitates, stops, agitates, stops, repeat, then spins.]]></title>
<description><![CDATA[<p>Whirlpool top loader old school mechanical timer washer. Circa 2005.</p>
<p>The labels on the machine say: Ultimate care II, imperial Series, quiet wash, commercial quality, super capacity plus, 10 cycles, 3 speed motor, 6 speed combinations, porcelain basket.</p>
<p>LSN1000LW0</p>
<p>Washer recently started doing this thing where if agitates briefly then stops. The timer carries on through the cycle. It fills and spins fine. I did the unplug it technique a few times but never to could get it to agitate much longer than 30 seconds at a time in any cycle except for in the extra low agitation cycle ( Delicates)</p>
<p>I have spent some more time observing this machine. My washer says it has 3 motor speeds. Low, high, and extra low agitation and low and high spin are named features of this washer.</p>
<p>4 cycle choices on the dial 1.) normal,-(superwash, heavy, regular, light)-High&amp;low agitation, high spin,</p>
<p>2.) Hand washable- intermittent agitation, low spin,</p>
<p>3.)  Extra delicates-extra low agitation.</p>
<p>4.) Casual Permanent press, high&amp; low agitation, low spin</p>
<p>So I Ioaded it lightly and watched it do an entire cycle on each of the 4 cycle settings without interfering.</p>
<p>Normal-It fills, agitates on high, pauses, agitates more, pauses (as if low agitation is skipped?). Timer continues to advance. It goes through this for the entire cycle. It then Spins. Fills for rinse and does the same routine on rinse cycle as during wash cycle. Agitate, pause, agitate, pause. So I started to think about how 3 speed motor operation might be a factor.</p>
<p>I switched to a cycle that says intermittent agitation.( Delicates,) And this cycle seems to work fine. ( Delicate pattern is Agitate, soak( pause) , agitate, soak.</p>
<p>Extra delicate cycle-extra low agitation. This cycle works fine. Yay! At least I can wash light loads on this cycle.</p>
<p>Ok so I'm starting to agree that the circuit that activates agitation levels is suspect.</p>
<p>But now there is more:</p>
<p>The washer tripped the breaker today in the middle of the extra delicate cycle. Pfft.</p>
<p>My family wants me to throw the thing away. I want to fix it.</p>
<p>Edit July 24</p>
<p>I tried to wash a extra light load. It fills and spins but no agitation on any cycle now.The motor hums and timer advances but no agitation at all on any cycle.</p>
<p>I needed a socket wrench extension to get bolt off agitator mechanism. I got one today. Indeed the agitator the dogs are toast. That explains a few things. But the lower agitator worked independently from the upper one previously. So I carried on with lower agitator diagnostics since I already had it taken apart</p>
<p>I found the agitator spline situation to be fine. So I'm moved to test agitator shaft function. I filled washer and observed the shaft. It no longer moves at all. But the machine does still fill and spin.</p>
<p>Does this indicate anything different?</p>
<p>I have ordered some of the contact cleaner stuff delivered. Local hardware store in my town did not have any.</p>
<p>But I'm starting suspect a transmission problem now. But I plan to check the motor coupling as well. ( I have already changed this part once about 5 years ago)  Any insight would be appreciated.</p>
<p>Edit July 25</p>
<p>Contact cleaner spray was found and applied to the timer mechanism as suggested. No change in above mentioned situation.</p>
<p>Thanks, Dee</p>
<p>⟐ Commented июля 25, 2026 at 18:11 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/961717/Washer+fills,+agitates,+stops,+agitates,+stops,+repeat,+then+spins.</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/961717</guid>
<pubDate>Sat, 25 Jul 2026 18:11:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Lid lock light blinking and will not do anything else]]></title>
<description><![CDATA[<p>Whirlpool top load wtw4816fw2 washer. Lid lock kept clicking right before rinse spin cycle. Online videos say it's the lock mechanism and showed a bypass to trick it to thinking it's always locked did that and it's no longer locked. Now the lid lock just flashes and it will not do anything. Any help would be nice.</p>
<p>⟐ Commented июля 20, 2026 at 11:27 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/715946/Lid+lock+light+blinking+and+will+not+do+anything+else</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/715946</guid>
<pubDate>Mon, 20 Jul 2026 11:27:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: The softener box is not working. How to fix it?]]></title>
<description><![CDATA[<p>My washing machine is not working with the softener box. In processing, the softener does not go out.</p>
<p>⟐ Answered июля 12, 2026 at 14:30 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/963221/The+softener+box+is+not+working.+How+to+fix+it</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/963221</guid>
<pubDate>Sun, 12 Jul 2026 14:30:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Duet Washing Machine: small leak at bottom]]></title>
<description><![CDATA[<p>small leak at bottom fixes</p>
<p>⟐ Commented июня 30, 2026 at 2:06 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/961785/small+leak+at+bottom</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/961785</guid>
<pubDate>Tue, 30 Jun 2026 02:06:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Washer stops at spin cycle, but drains. Drain and spin cycle works?]]></title>
<description><![CDATA[<p>Hi,</p>
<p>I'm having a hard time finding an answer to this specific scenario. My Whirlpool washer model # WTW4815EW0, about 4 years old, recently stopped spinning out clothes at the end of a wash cycle. We use both the normal cycle and bulky items, and this occurs on both. The problem began gradually, only sometimes would the washer not spin out at the end of the cycle. Now it's every time. However, the strange part is that mechanically it has no issue spinning. After it decides to quit on the wash cycle (clothes are clean and tub drained, but still sopping wet), I just set it to drain and spin and it finishes the job without problem. So I don't think it's a lid latch, a belt, or anything that would stop it from spinning ever. What do I need to do to fix this? The washer was cheap to begin with and the cost of a repair person could easily cost as much as it did new, so if it's not something I can fix on my own I'll just get a new one. Thanks for any help.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_09_08_Num_2019" class="header">Update (09/08/2019)</h3></div>
<p>I have some updated information. I ran some manual tests and found that the washer spins on low but not on high speed. The low speed test runs without issue. During the high speed test, the motor kicks in for just a second and then immediately quits, with lid lock light flashing. I performed a tachometer test which it also seemed to fail. I checked the belt underneath which looks good. Drive test performed good. Control board has no obvious damage.</p>
<p>⟐ Commented июня 29, 2026 at 14:38 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/588443/Washer+stops+at+spin+cycle,+but+drains.+Drain+and+spin+cycle+works</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/588443</guid>
<pubDate>Mon, 29 Jun 2026 14:38:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Whirlpool lid lock bypass]]></title>
<description><![CDATA[<p>I have a Whirlpool wtw5000dw1  and I'm trying to bypass the lid lock by cutting the wires. They are res white and blue. Which two should I cut?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_06_29_Num_2019" class="header">Update (06/29/2019)</h3></div>
<p>*red, white, and blue</p>
<p>⟐ Commented июня 20, 2026 at 6:30 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/575981/Whirlpool+lid+lock+bypass</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/575981</guid>
<pubDate>Sat, 20 Jun 2026 06:30:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag or Whirlpool Centennial washer: Top loading wont do anything but hum I move the drum it stops then sta]]></title>
<description><![CDATA[<p><strong>Button doesnt light up ,no movement,grinding noise</strong></p>]]></description>
<link>https://ru.ifixit.com/Answers/View/958359/Top+loading+wont+do+anything+but+hum+I+move+the+drum+it+stops+then+sta</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/958359</guid>
<pubDate>Fri, 05 Jun 2026 14:08:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: My frigidaire top load washing machine won't continue any cycle.]]></title>
<description><![CDATA[<p>The lid locks and the water will start to fill but only for a couple of seconds then stops. The same with draining. It will start to spin but only for a few seconds. I can hear clicking sounds from the motor control unit but then it stops. I've replaced the lid lock assembly. Also, when I begin the cycle, the washing machine will not spin to sense the cycle.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_02_19_Num_2020" class="header">Update (02/19/2020)</h3></div>
<p>Frigidaire Affinity FAHE1011MWO</p>
<p>⟐ Commented мая 12, 2026 at 14:57 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/618350/My+frigidaire+top+load+washing+machine+won&#039;t+continue+any+cycle.</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/618350</guid>
<pubDate>Tue, 12 May 2026 14:57:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: F9E1 whirlpool washer won't drain FIXED]]></title>
<description><![CDATA[<p>UPDATE: NO POLARITY. CONNECT THE WIRES HOWEVER YOU WANT. Wtw5100hw0 wouldn't drain, so I checked the hose for clogs. Checked the plug for continuity and nothing. I found a break in the wire so I fixed that. Check continuity and nothing, I cut the connector off and both wires have continuity. Now the problem is I can't find the connector I cut off. I have female spade connectors on the wires but have no idea which wire goes to what terminal on the pump.</p>
<p>⟐ Edited by author мая 03, 2026 at 15:19 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/952819/F9E1+whirlpool+washer+won&#039;t+drain+FIXED</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/952819</guid>
<pubDate>Sun, 03 May 2026 15:19:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Whirlpool 1cwtw4845ew1 toploader cold water valve solenoid?]]></title>
<description><![CDATA[<p>The above mentioned washer refuses to fill up on the cold water side randomly, basically you can hear an electric humming sound but no water enters. So I have already figured it must be the solenoid going bad (or am I wrong)? Hot water side works just fine. Did the manual check, and indeed cold water side throws an error. Question: I already found the whole inlet valve available, but I suppose just the cold water solenoid is not available for purchase? Or is there another fix I could use. The part (whole valve body with hot and cold water) is rather expensive, so if at all possible, would rather not purchase it right now.</p>
<p>⟐ Edited мая 03, 2026 at 1:35 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/953084/Whirlpool+1cwtw4845ew1+toploader+cold+water+valve+solenoid</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/953084</guid>
<pubDate>Sun, 03 May 2026 01:35:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Clothes sopping wet at the end.]]></title>
<description><![CDATA[<p>2 year old Whirlpool wtw5000 top loader.</p>
<p>Washer washes, rinses and drains fine, water pumps out like crazy. It's spins. I'm not sure how it's supposed to spin compared to our old style washer. It spins stops , pumps some water, spins and stops pumps some water and then it's done. But there's still some water down below and clothes are sopping wet? The darn thing takes so long to do a load of clothes I've never really paid attention to what it does and when. So everything seems normal except the clothes are wet.</p>
<p>⟐ Commented апреля 29, 2026 at 19:19 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/387411/Clothes+sopping+wet+at+the+end.</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/387411</guid>
<pubDate>Wed, 29 Apr 2026 19:19:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Why F - 28 shows up on the display and door not opening]]></title>
<description><![CDATA[<p>Why F -28 flashing on the display and door not opening</p>
<p>⟐ Commented апреля 29, 2026 at 0:58 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/415954/Why+F+-+28+shows+up+on+the+display+and+door+not+opening</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/415954</guid>
<pubDate>Wed, 29 Apr 2026 00:58:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: an oL code comes up]]></title>
<description><![CDATA[<p>My Whirlpool Cabrio washer was just moved in.  It is an older one and works until it gets near the end… an oL code comes up and the clothes aren’t completely spun out…. I need suggestions…. Wondering if it can be related to the computer due to the move.</p>
<p>⟐ Edited апреля 28, 2026 at 9:26 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/952488/an+oL+code+comes+up</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/952488</guid>
<pubDate>Tue, 28 Apr 2026 09:26:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: I can't get the control lock off.]]></title>
<description><![CDATA[<p>I can't even find a picture of my washer when it comes to this matter. It says to press and hold the control lock button for 3 seconds, there is no button there it's just the light. This is a whirlpool duet front loading steam washer and the control lock light is on I've got to do laundry please help me please help me today</p>
<p>⟐ Commented апреля 28, 2026 at 9:23 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/809578/I+can&#039;t+get+the+control+lock+off.</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/809578</guid>
<pubDate>Tue, 28 Apr 2026 09:23:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag or Whirlpool Centennial washer: Leak when spin drying]]></title>
<description><![CDATA[<p>My washing machine will leak when spin drying</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/951115/Leak+when+spin+drying</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/951115</guid>
<pubDate>Sun, 19 Apr 2026 08:38:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Whirlpool 1cwtw4845ew1 toploader engaging lid lock non-stop]]></title>
<description><![CDATA[<p>Whirlpool washing machine 1cwtw4845ew1 was in the middle of the washing cycle when it started engaging and disengaging the lid lock randomly, and now it won't do anything else anymore. Tried reset as per a Youttube video, but the lid lock keeps on clicking non-stop when the machine is plugged in.</p>
<p>⟐ Commented апреля 18, 2026 at 10:22 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/907409/Whirlpool+1cwtw4845ew1+toploader+engaging+lid+lock+non-stop</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/907409</guid>
<pubDate>Sat, 18 Apr 2026 10:22:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[Maytag or Whirlpool Centennial washer: I need to know a component from the main board]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/KAdUoqEGgoKDqphC.standard" width="104" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/KAdUoqEGgoKDqphC.full&quot;, '', 'width=1080,height=2340')" /></div>]]></description>
<link>https://ru.ifixit.com/Answers/View/948798/I+need+to+know+a+component+from+the+main+board</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/948798</guid>
<pubDate>Sun, 05 Apr 2026 14:28:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Why is my washer still not working after I replaced the lid switch cyc]]></title>
<description><![CDATA[<p>I replaced the lid switch on my whirlpool 2in 1 removable agitator washer due to a broken clip after replacing the washers an entire cycle threw no problem wen I went to start the nxt one it wouldn't work all the sudden I looked up and tried most every diagnostic entry and nothing has worked so far I need help</p>
<p>⟐ Commented апреля 04, 2026 at 21:37 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/948674/Why+is+my+washer+still+not+working+after+I+replaced+the+lid+switch+cyc</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/948674</guid>
<pubDate>Sat, 04 Apr 2026 21:37:23 -0700</pubDate>
</item>
<item>
<title><![CDATA[Whirlpool Washing Machine: Machine makes Grinding/growling noise]]></title>
<description><![CDATA[<p>Machine makes noise at end of cycle.  I can still use machine after a reset but have to unplug it between washes.</p>
<p>⟐ Commented марта 17, 2026 at 1:57 GMT-7</p>]]></description>
<link>https://ru.ifixit.com/Answers/View/945355/Machine+makes+Grinding-growling+noise</link>
<guid isPermaLink="false" >https://ru.ifixit.com/Answers/View/945355</guid>
<pubDate>Tue, 17 Mar 2026 01:57:30 -0700</pubDate>
</item>
</channel>
</rss>
