Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
19981вопросов Показать все
would you be able to fix water damage on a MacBook Pro?
I got not a lot, but enough to do damage, amount of orange juice on my laptop. Going to apple it was said to be priced 1200 dollars to be rebuilt, is there any way you could help me at a lower rate?
Это хороший вопрос?
Оценка 0
1 Комментарий
iFixit is not a repair service, it is a resource to help you repair yourself. By asking here and consulting guides and being able to purchase parts and tools you can do by yourself for less what would have been a costly repair job.
из
Добавить комментарий
2 Ответов
Выбранное решение
Good chance it can be fixed for much less. Was it on when the juice got spilled? What happened to the computer? It can most likely be cleaned using distilled water. We need to know exactly which MacBook Pro you have to direct you to a teardown. Did Apple open it up? What did they do?
Был ли этот ответ полезен?
Оценка 3
3 Комментариев:
This should be a comment, not an answer.
из
Cleaning with distilled water is not a comment.
из
Your answer was hidden in a plethora of questions, now that I see you indeed have an answer in your answer, I will reverse the downvote. I hope you will also revert the spam downvotes you just did to my account. Thank you
из
Use NON Conductive Component spray which you could find at Radio Shack and generously spray down everything internal including the motherboard and all surrounding components. Allow the MBP to rest in a well ventilated area for 1 hour..it did the trick for my 2010 Macbook Pro i7 which I made add is working perfect.
Оценка 0
Добавьте свой ответ
allie будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,348
