NO SOUND OUTPUT. Help
I have been in the sound settings but I cant ajust the sound as it is not highlited. The message in the box says; THE SELECTED DEVICE HAS NO OUTPUT CONTROLS.
How can I activate?
Many thanks
Это хороший вопрос?
How can I activate?
Many thanks
Это хороший вопрос?
Mark,
The computer is most likely stuck in the digital output mode. If you look in your headphone jack, you will probably see a red light. Most searches for support will suggest a toothpick to disengage the tab inside the headphone jack.
Others have had success by inserting a 3.5mm plug in and out repeatedly until the tab releases and the computer no longer thinks there is a plug in that jack.
Here is more on that.
Good Luck
Frank
Был ли этот ответ полезен?
+1 Ralph
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 770
1 Комментарий
- vote for asking the same question three times in 7 hours. Try to stay with your original question please
из mayer
