Can I change hard drives from one playstation to another
I have a playstation 3 that will not read the disks, so I have purchased another ps3 just like the one I have. Can i take the hard drive out of the first one and put it in the second one so I don't lose all my game data
Это хороший вопрос?
Оценка 6
2 Комментариев
Shane’s assessment is correct. You cannot just slip in the old hdd, and get all your saves back.
из
I need to take hard drive out of old psp3 but it has no flapt. cannot find answer on the web. square looking box belonged to my son not like one in your photo, that I got was easy.
из
Добавить комментарий
12 Ответов
Наиболее полезный ответ
Upgrade to the newest firmware on both PS3s and there will be a new utility in the settings that will allow you to copy all of your files from one PS3 to the other using an ethernet cable (you can even transfer copy protected files and game saves that don't normally allow copying).
You cannot just remove a hard drive from one PS3 and put it in another and expect all information to transfer over. You will have to format the drive.
Был ли этот ответ полезен?
Оценка 9
3 Комментариев:
Since the systems are hardware identicle, there should be no problem swaping a hard drive from one PS3 to another, if it were to be used in a PC, or other device it would need to be formatted, but it should be able to be swaped without a problem, just like Xbox 360 Drives.
из
Great assessment!
из
what if only one hard drive is working , i have two ps3’s , the one i use is very slow, but has all my stuff in it , and the other one works just fine exept its hard drive is corrupted and it wont even turn on
из
Yes, depending on whether you have a slim, or not, the procedure is different, but you should have no problem with compatibility. I don't have a PS3, so I'm not sure how you remove the slim's hard drive, but I have worked on "Fat" PS3's and the hard drive is on the side, just pop off the cover, and remove one screw, then the drive.
Оценка 3
1 Комментарий:
PS3 door in the front to remove the hard drive 1 screw remove the cover and you pull it out
из
As Shane said, it's physically possible to take the drive out of one PS3 and into another but it won't preserve all your data. Use the transfer utility, it works quite well and if you've only got a few things then it won't take too long.
Another way, depending on what you want to save, is to backup your saved games etc to a USB hard drive and then copy them to the new PS3. You can't copy everything, but by-and-large you can copy everything you can't replace by downloading again.
Оценка 2
1 Комментарий:
What if only one of the ps3 is functioning the other was baught for parts and wont even turn on im trying to bypass having to unjailbreak a ps3 that i purchased i dont want the jailbreak which way is easier
из
If you have the new firmware update 3,56 it isnt possibel to swap / upgrade harddrive in a ps3.. I hope Sony soon will com with a new update to fix this bug - so my PS3 can come up and running again.
Оценка 2
1 Комментарий:
I am not aware of the bug in the 3.56 firmware update.
из
buy ps plus and save your data on your account then get new ps3 then you will be able to still have yoru stuff
Оценка 2
You could back up your data though the backup utility in the PS3 system's menu. Get a USb flash drive, or if needed a USB external USB drive to back up your system settings, game data and game saves.
As for any downloadable content, any games or media purchase from the Play Station Store can be re downloaded with out an additional charge.
Оценка 1
Yeah might work it just depends on what the problem is
Оценка 1
1 Комментарий:
из
I swapped out hard drives in my PS3 and had no problems...
Оценка 1
1 Комментарий:
What do you mean? You took a hard drive from one ps3 and put it in another and it worked?
из
I need help fixing my ps3. It won't making that nosie when it checks for disks plus it keeps saying file courpted and after it reloads everything goes black and it says the same thing again.
What's wrong with it.
Оценка 1
I have a PS3 backwards compatible burnt up can I take the hard drive out of it and put in it in another PS3 backwards compatible
Оценка 1
What happens to a banned ps3 hard drive in to another ps3 that is ot banned ?
Оценка 1
Can you use a PlayStation 3 hard drive in a PlayStation 4
Оценка 1
Добавьте свой ответ
Teena будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 19
За последние 7 дней: 122
За последние 30 дней: 490
За всё время: 99,525
