Hi,
First of all you need a way to plug any HDD to your USB or Firewire in order to retrieve your old data.
Now, you will need to remove HDD-320 and replace it with HDD-750. I will need your MBP's model to point you to the proper HDD installation guide.
Once the HDD-750 is in ou will have to format the hdd. this is when you can create your partitions. Just remember that they the one running osx needs to be journaled extended. When you are done with the partitions, proceed to install OSX. At some point it will ask if;
-You want to do a clean install. If you opt for this, you will have to move your data, do all the settings and re-install your programs.
-You want to restore a previous account. This will pull the data from HDD-320 and will leave HDD-750 with an exact copy of your old install.
Either way, you will have to be able to access HDD-320.
So, you should now have a clean install to work with or a restored version of your old system. Now you can run Boot Camp Assistant to install W7.
If you have any questions, please add them as comments.
Cheers,
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
3
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
