When your iPhone gets stuck at the Apple logo and does not boot up completely, it triggers a mini heart-attack. But it’s not all that serious. You can fix this through a couple of ways.
While the first method shows you how iTunes can help you, for the second method, you’ll need a tool like TinyUmbrella.
Let’s take a look at how you can fix an iPhone stuck at the Apple logo during boot:
Step 1: Connect the iPhone to your computer via the USB cable.
Step 2: Put your iPhone in DFU mode
Step 3: Now, all you’ve got to do is ‘Restore’ your iPhone
Now, that’s the simplest way to get your iPhone out of the Apple logo. But what if you have data that hasn’t been backed up? Or if you’re getting errors when you try to restore?
We’ve covered some material on iTunes errors: the most notable errors that you’d be getting are 1014, 1015 or the 16xx series of errors. You can fix these by taking a look at our coverage on iTunes errors.
If your iPhone is stuck on the Apple logo and you’ve got data that needs to be backed up, I’m afraid you’ll mostly lose the data unless you can kick the iPhone out of the Apple logo by other means. By this, we mean you can use tools like Tenorshare ReiBoot to fix the recovery mode problem.
More back-up methods you can see here like on how to:
recover whatsapp messages from itunes backup
retrieve deleted whatsapp messages from iphone
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
1 Комментарий
http://gsm07.blogspot.com/2015/11/octopu...
из khanbuledi
