Is 'digitizer ribbon cable' of nexus 7 replaceable?
I have accidentally cut digitizer ribbon cable of Nexus 7, can it be replaced?
Это хороший вопрос?
Это хороший вопрос?
Assuming this is what you cut, you should be able to replace it.
Otherwise you might have to replace the whole display assembly, but I would try the LCD cable first before replacing the whole display assembly.
Был ли этот ответ полезен?
Thanks for your response =), thats not one which I broke, but I was able to get my cable repair from local market.
Hi Naveed, did you get the guy from the "local market" to replace just the cable? Mine got pulled off as well and as far as I can see, the ribbon is stuck to the digitizer by some sort of adhesive. Not sure how that works with establishing electrical connections though.
Does anyone know how I can reattach the digitizer ribbon?
Can be purchased here
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 5,334
