Partial Sync and then error.
This is a built from parts ipod classic 80GB, so I am not sure the history of the board or hard drive.
Will sync around 3GB and then an error appears. When I disconnect the ipod there is actually only a few songs on it.
I have ran chkdsk for errors and it found none. I have reformatted.
Update
I just replaced the hard drive and its now working.
Это хороший вопрос?
What error appears? when you format, what capacity does it give you at the end? Has it worked before?
из oldturkey03
iTunes could not copy "..name of song..." to the iPod because of unknown error occurred (-50). 74.34. This ipod is from left over parts from multiple broken ipods.
из Steven
-50 is usually caused by iTunes not connecting to the iTunes store :) Arte all of your music files in your own library on your computer? What OS are you using?
из oldturkey03
When it failed I tried my iPod 120GB and it worked. Are you not allowed to use more then one iPod? All files are in one location on the internal hard drive. XP.
из Steven
Right now, and with the error message you receive, it sounds more like an iTunes issue :) Have you tried to placed the iPod into diagnostics mode and checked on your HDD in particular?
из oldturkey03
Показать 7 больше комментариев
