iPod won't power on
I have replaced battery and new click wheel but the iPod will not power on
Это хороший вопрос?
Это хороший вопрос?
I recommend opening up the iPod and making sure everything is plugged in correctly. Sometimes a problem like this is caused by a simple loose connection. Will the iPod turn on if plugged into a computer? If it does, then you may need to restore the iPod and let the battery fully charge.
Был ли этот ответ полезен?
The iPod has a battery symbol with a lightening bolt in it . what is the problem??
How do i repair it??
The mini shows the charging animation (battery w. lightning bolt) when it's charging in standby mode (only when it's not connected to itunes)
Replaced the battery-now the ipod will not go on only the applee logo stays on even i put it on the charger on?
how do i know if mi ipod needs new battery
hi i need help how do i know if my ipod touch needs new battery it dont start i almos buy the battery
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 9
За всё время: 7,028
