Model A1051 / 4 or 6 GB hard drive
Вопросов 20 Показать все
iPod won't power on
I have replaced battery and new click wheel but the iPod will not power on
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (5)
Наиболее полезный ответ
I recommend opening up the iPod and making sure everything is plugged in correctly. Sometimes a problem like this is caused by a simple loose connection. Will the iPod turn on if plugged into a computer? If it does, then you may need to restore the iPod and let the battery fully charge.
Был ли этот ответ полезен?
Оценка 1
I don't know how to get music on it
Оценка 1
The iPod has a battery symbol with a lightening bolt in it . what is the problem??
Update
How do i repair it??
Оценка 0
1 Комментарий:
The mini shows the charging animation (battery w. lightning bolt) when it's charging in standby mode (only when it's not connected to itunes)
из
Replaced the battery-now the ipod will not go on only the applee logo stays on even i put it on the charger on?
Оценка 0
how do i know if mi ipod needs new battery
Оценка 0
1 Комментарий:
hi i need help how do i know if my ipod touch needs new battery it dont start i almos buy the battery
из
Добавьте свой ответ
strilerscarecenter будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 7,101
