Where is the Airport Antenna?
Hi !
I've got the "No Airport Card installed" syndrome ...
I did my own researches and decided to open the MBP and check the wires : no improvements !
Then I changed the airport card following a guide on this website : no improvements !
So I'm wondering if the failure comes from the antenna ...
I've given a close look to the LCD dismantle and this antenna seems to be in the bottom of the screen, and there might be no use to open completely the screen (heater gun, etc.)
Is that correct ? Am I in the right way to solve my problem ?
Thanks
Это хороший вопрос?
1 Комментарий
Did you reset your PRAM and SMC after disconnected and reconnected everything? If not give that a try. Also check and see if you have any other USB devices (iSight, ports, etc...) not working, the Airport is piggy backed into the USB.
из ABCellars
