battery wont charge but the mac Power Up, after repairing the magsafe
I have repaired the magsafe connector many times, but yesterday I was repairing and accidentally reversed the polarity, and plug it into mac while it was running from the battery. it did not do anything like a spark or shutdown the mac, and the Orange LED did not turn on. So, i thought to check the polarity again and it was wrong.
Now the mac powers up from a charger but it does not charge the battery,
I check the battery it has 270 cycles on it and it is recognized by the mac, and i used another new charger an it is the same.
So i was wonder if anyone had the same experience or knows anything about this,. I am not sure if the DC-board has fuses or anything that could be fixed.. Please tell what to do .. Thanks
Model Information:
Manufacturer: Sony
Device name: ASMB012
Pack Lot Code: 0001
PCB Lot Code: 0000
Firmware Version: 0110
Hardware Revision: 0500
Cell Revision: 0303
Charge Information:
Charge remaining (mAh): 316
Fully charged: No
Charging: No
Full charge capacity (mAh): 2619
Health Information:
Cycle count: 270
Condition: Check Battery
Battery Installed: Yes
Amperage (mA): -2
Voltage (mV): 11654
Connected: Yes
Wattage (W): 0
Revision: 0x0000
Family: 0x0000
Serial Number: 0x00000000
Charging: No
Это хороший вопрос?
Theres a set of power transistors which you most likely blew when you reversed the polarity on the left I/O board.
из Dan
