Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
187вопросов Показать все
Вопрос закрыт
dual hard drive kit with Samsung 830 series 256GB drive
I added a Samsung 830 series 256GB drive to a late 2012 mac mini using the ifixit dual drive kit. No issues with the installation or formatting the new drive. However, the drive is very flaky (randomly dismounts during long file copies, gives error messages when trying to repair in Disk Utility, etc) inside the mini versus outside in a bus powered external usb 3 enclosure. Disk Utility will format consistently, it is not consistent in the repair mode where it gives warning messages that the disk cannot be repaired.
I am copying all the files using the external enclosure to confirm that doesn't fail and then move it back into the mini to see if the flakiness is still there.
Anyone else with any experience using Samsung 830 series SSDs in the late 2012 mac mini?
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
i faced the same problem. i use a 830 512g ssd, in a mini late 2012. when i start the mini ,to install max os(10.8.2, in a flashdisk), prohibitory sign on screen at startup. i changed the flashdisk, and it also doesn't work. i checked every step, nothing wrong.
who can deal with it
Был ли этот ответ полезен?
Оценка 0
syifeis,
I have the same issue you are presenting but with an OCZ vertex 4 256gb
i believe its apple fault... my ssd it's working in my macbook pro now...
Оценка 0
I have two of them in my mini, seem to be working well. Bought around the same time as yours too. I haven't particularly stressed them both at the same time but have been running a VM on the disk attached via the ifixit cable. So far so good, after a week or so.
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,271
