1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192вопросов Показать все
Вопрос закрыт
Can I take out the SSD and install into external case?
I broke my MBA and its completely smashed. Luckily (I think) the SSD is still in good shape.
Any recommendation on the external case (brand) for the SSD? Also, I plan on buying the latest MBA. I assume this will not be compatible with the old SSD right?
So is there a way for me to boot from the external drive? I would like to restore my image as much as I can (in terms of settings).
Thanks in advance!
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Here's one case you could use: OWC
To move your stuff over use Apples Migration assistant app.
Был ли этот ответ полезен?
Оценка 1
yes you can take it an an external sata case. ´Than you can copy the files to your new computer
Оценка 0
2 Комментариев:
Thanks. Does that mean it'll be in SATA speed (or based on the connector) ?
из
Sadly, no. The external connection speed is limited by the I/O used: USB1/2 slowest, Firewire400, USB3 (shared link), Firewire800, USB3 (dedicated), Thunderbolt being the fastest. You still have the limits of the device which may not be able to sustain the connections bandwidth.
из
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,342
