Repair guides for the MacBook Air, Apple's current line of consumer laptops.
4656вопросов Показать все
Odd keyboard issue after water damage
Right, poured my hot cocoa in the 'return' key area. Was not a lot - immediately flipped upside down and powered off while using paper towers. Waited a few minutes and it worked fine.
A day later, the spacebar and a couple other keys suddenly stopped working. As far as I can tell, no keys are sticky.
Question:
- Would popping each key out and cleaning help or am I wasting my time and risking further issues?
- Roughly how much are we speaking to have the keyboard replaced at Apple?
Thank you.
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Apple is always expensive and you should be able to fix this yourself, there is a Teardown Guide here MacBook Air Repair and treat the problem area for the liquid damage with alcohol and a tooth brush or whatever tool would work best, it's not a tough thing to do ! Good Luck. If this answer was helpful please remember to mark it accepted.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
ElCapitan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,022
