Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
585вопросов Показать все
Keyboard after spill replacement or cleanup?
I have the same problem, i spilled oil over my keyboard. Since that some keys need to be pressed a lot harder to work as normal. I already took of some of the Keys to clean below. Which helps a lot, for a couple hours they work fine.
But after a they return to their old status.... I guess that there is still oil that gets back an between the contact under the keys.
So i guess i would have to clean in between the layers of the keyboard.
Can i get in between the plastic foil and the contacts by disassembling the keyboard?
As well if you would recommend to replace the keyboard entirely, which is the repacement keyboard that corresponds to my one?
I have an Early 2011 MacBook 15"
Thanks for any help!
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Time is money, unless you're unemployed. While it is "possible" to dismantle, clean and reassemble the keyboard only you can determine if that's the best use of your time.
This is the part you need, maybe you can find a keyboard only some place... but again pulling the keyboard out and fitting a new one won't be easy, as they were designed to be part of a single component.
If this answer was helpful please remember to mark it accepted.
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Upper Case Изображение
Продукт
$299.99
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Nikolas Sariyannis будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,028
