Третье поколение Toyota Camry на всех рынках за пределами Японии. Модели 1991–1996 годов также известны как серия Camry XV10.
Why won't my sterio work?but did before?
i put a cd player in my car before and switched it out for a newer cd player.now that i put a new one in it won't work.i double checked to make sure all wires where right and fuses...What else could it be for it not to work?
Это хороший вопрос?
Счет 1
2 Комментариев
Is it an aftermarket stereo or a Toyota brand? Do you use an amp with it? What was the issue with the old one? You just replaced it to go with a newer player?
из
i just replaced the stereo for a newer one. there is no amp connected.ok i will check the wires again..thank u both very much
из
Добавить комментарий
1 ответ
Выбранное решение
First thing I would do is test the power wire to the stereo with a volt meter and see if you are getting 12 volts from it and at the same time make sure the Ground source is also working, if that is good I would look for a fuse that is in the stereo itself and see if it's good, if that's all good then I would have to think the stereo may be bad.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
gamesnotwar буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 20
За всё время: 727
