Why isn't my mouse working?
My mouse won't show up on my screen and I can't click on anything. The laptop is brand new and I'm already having trouble.
Это хороший вопрос?
Это хороший вопрос?
Check for a function key that turns the built-in mousepad on and off. Mine is a silver button on the top left of the keyboard. It drove me crazy until I discovered it.
Был ли этот ответ полезен?
On my laptop apparently it's Fn + F9. Thank you! It was driving me crazy too.
I want to thank you because me too was driving me crazy.....I have been trying for hrs to figure it THANK YOU again....
GOD Bless you - Fn F9 fixed it immediately. Thank you
Thank you. I had the same problem and I used Fn F9 and the issue solved.
thank you! Fn F9 fixed it
You have to restart the computer and after restart the computer, It would be work
and after restarting if mouse doesn't work so..
You have to update the drivers . for additional steps visit '''FIX-mouse-not-working-in-computer'''
Follow these Steps:
a) Press the Windows + R key on the keyboard.
b) Type devmgmt.msc in search box and click on OK
c) Right Click on Mice and other pointing device
d) Click on update drives then click on Search automatically
Then restart the computer.
After that Mouse doesn't working So:
Then try to change USB port of Mouse. Please let me know for any other issue .
How are people supposed to click on those things if their mouse isn't working?
that is exactly what I'm saying
I was Thinking How You Even Got Here ... Use Your Phone..Thank You Peter
Thank-you! A reboot fixed the problem.
thanks bro
If the mouse is a corded USB, try it on a different computer, if it works, then plug the mouse into a different port on your laptop. If it is a wireless mouse, check the batteries, and try moving the USB receiver to another port and installing the drivers.
If that doesn't work, when the system powers on go into the BIOS setup and make sure that all of your USB ports are turned on.
If it is the trackpad, and you are having other issues on a brand new laptop, you may need to contact the company where you ordered it from and let them step you through any specific troubleshooting problems and/or request a RMA or refund (worse case scenario).
I will keep that in mind and be more specific with other questions. Thank you.
oh my GOD ! iam a woman and i am very lack with those things!! and you just solved my problem in a minute . oh my god . thanks and my God bless you.
what the !&&* does being a woman have to do with installing a mose?
I tried all above options. Fn+F9 ....touch pad disables but still mouse does not work. I tried different ports, doesn't work. I assumed ports are damaged (my kitten often walks on laptop as red carpet) but external fan and printer are working excellent on same port. What do I do? How to reinstall mouse? Please advise me. It is time consuming with touch pad, mouse is faster
mine is a laptop and i can't see or move the mouse
On new touchscreen Asus laptops the trick for turning on the mouse is to press fn+f9. I had to go three weeks like this until I could figure out what to do. Also if your screen gets turned sideways or upside down. {my brother did that to mine} press ctrl+alt+up arrow. If you press the wrong arrow do it again until it goes back to normal.
dont work on mine
man i love u
Mine doesn't work it's a toshiba ?!? Any help
i have a toshiba its a brand new laptop only had it for a couple months then the other day the mouse just disappeared. i tried the fn f9 but its not working
I have toshiba its a new laptop I tried the fn f9 but its not working..any help please!?
It seems that there are many Fn + F- keys if you see on your Pc look for a F- button with what looks like a No symbol, you know the one with a circle with a line through it and a hand to the right pointing at it. For me i Pressed Fn+F7 and that worked if this helps anyone yw. Good Luck
I bought a new asus r558u with dos.I had to install Windows 10 using Keyboard only..I thought it was drivers problem....then fn+f9 made the pointer to come back...thank you very much
@xpzharlock thanks a lot sir the way you described the function key's special function symbol helped me a lot thanks a lot from bottom of my heart as i was like how to fix this issue what has gone wrong etc. as i followed few suggestions like fn+f9 but that didn't solved the case
i am really thankful to you that you explained in such a fantastic way thanks a lot sir
with regards
MOHAMMED MUZAMMIL
my fn key that looks like a no is f9 and it still doesn't work.
F7 worked! Lifesaver
try pressing [fn] + f1 or wherever the icon of a computer screen with an x is on. Hope it helps!
Yay. I was going nuts. Thanks. On mine it was Fn F10. The description of the icon was very helpful.
THANK YOU!!!! This has been driving me crazy for weeks!
Thank you!!!!!!!!!!!!!!!!!!!!!!!!!! It was stuck and not showing on screen. It was driving me crazy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! THANKS!!!!!!!!!
YOU'RE A LIFE SAVER I DIDN'T KNOW WHAT WAS GOING ON- also the button isn't a computer screen it's a touchpad lol, makes sense since it turns the touchpad on and off.
Thank you ...?
I am sorted good people.
click the button that gets you into the asus vivo book mode. it's a little diamond iconed button on the top right corner of the keyboard for me.
then you have this little profile of your comp come up, like memory used, etc, and one has the touch pad either on or off. somehow mine was disabled and put into off. I switched it on on and my mouse icon came back!!
My ASUS mouse has a small on/off switch on the bottom. More like on/gotcha switch!
I tried every suggestion on here and a couple other sites. Fn + f9 or fn + anything else didn't work. I did try fn + f3 and it worked! apparently it's the f key with the symbol that looks like a mouse and a line across it from one corner to the other (the x one didn't work on mine either). Hope this works for those who are still trying to figure this out.
Tried everything. Still not working.
I have a problem..usb mouse not working. I try search net to settle it. I find out...can on back USB device with enable device icon click..to get it working back.
Go device manager there click into universal serial bus controllers then click choice composite devices properties that have enable icon button , just click on it..to open the USB device function back. After follow the step ,click next then USB mouse function back like normal.
I just purchased a new ASUS laptop. I updated to Windows 10 immediately so I could get used to everything all at once. I use a small external mouse for travelling, and the touchpad quit working the second I plugged it in. Even after I disconnected it from the USB and restarted, the touchpad still would not work. I was told this is a bug and they are working on it.
After I read through the comments here, I went to Settings, Devices, Mouse and Touchpads, Additional Mouse Options and there it was under ELAN it said it was disabled. I enabled it, and now I can use the touchpad!
Thanks!!
I don't see any E-LAN.
Honestly, I just turned my computer off and on again. You may need to restart it, though. My mouse was freezing and when it was moving, it would just be zooming the screen in or out. So far it's working, I'm not sure if this fix is permanent. Ironically, it was the last thing I tried, but it should've been the first thing I tried.
I Think You Should Checkout This See If This Helps -
Unplug Your Mouse and Wait For 1 minutes And Plug It Back
Restart Your Computer In Safe Mode With Networking
Follow Steps To Get safe Mode Visit How To Boot Windows Computer In Safe Mode Now In Safe Mode Please Go to device Manager And Update the Mouse And Pointer Driver .
Restart The Computer and Get Your Mouse Working .
Hopefully this May Work
My fix was fn+F1. I'd suggest looking in your function keys and pressing fn+the function key that has the diagram of the toupad on it.
My Acer laptop has the touchpad sign of a pointing finger at F7.
За последние 24часов: 13
За последние 7 дней: 80
За последние 30 дней: 402
За всё время: 542,959
40 Комментариев
I have labtop and I've tried every trick that you guys are giving...I get nothing, any more ideas?
из gary
mine says device not migrated om on windows 10 help
из Pois0nz Tech Videoz
My mouse has a red light when i turn it on {Witch means its working}.
But the mouse icon itself will not move around i am working on a project
please reply
из Tj Cook
i have a desktop got 10 day before yesterday, lazer light is on but screen mouse arrow doesn't move, any ideas?
из Vince Barenchi
roll back worked a treat
из robbied336
Показать 35 больше комментариев
