Where is the wiper relay?
My wipers recently went out on my Focus. I have checked voltage at the wiper motor and have DC coming in on all wires but the black/white. It's either due to a bad wiper relay or the wiper/washer switch. I would like to check the relay before breaking into the steering column, but I cannot find it. The wires go into the distribution box, but I cannot find out where. The web has advised the relays are under the dash, but they are not.
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
danielelphinstone, check the fuse box under the hood. The relay is attached to it.
Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 1
You find here a fuse box description and diagram for Ford Focus
Europe version
http://www.autogenius.info/en/ford-focus...
USA version
Оценка 0
My wipers went out on me, as soon as I turned my car off. I would like to know, What's the number on the fuse for my wipers. On a Ford Focus, 2007.
Оценка 0
Добавьте свой ответ
danielelphinstone будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 9
За последние 30 дней: 54
За всё время: 27,303
