Repair information and guides for MacBook Pro models with 13" displays.
9729вопросов Показать все
Вопрос закрыт
hooking up to Viewsonic monitor VA720 15 pin HD D sub (hd15)
Dropped the Mac the glass broke screen showed a whtie streak down the middle.
Replaced the screen and it doesn't come on, doesn't show anything.
To check if anything else might be broken, I want to try use the mini display port to connect it to an external monitor that I have, Viewsonic VA720 and I'm not sure its compatible.
I know I have to get a cable to connect to the monitor, any suggestions on where i might get one. If its compatable with ehr monitor.
Это хороший вопрос?
Оценка 0
1 Комментарий
check the link from "Gabe" on your other question about the same issue.
из
Добавить комментарий
1 ответ
Выбранное решение
Yes you can, just use one of these adapters!
Был ли этот ответ полезен?
Оценка 1
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 254
