Takes a long time before it boots up!
When powering on the CAPS Lock light flashes slowly 4 times, the fan is running high and I have to wait sometimes up to 10 minutes before it boots. Sometimes it will boot up less time than this and some of the time it can take half a day to boot but when it has booted it runs fine.
Thanks for your help.
Paul
Это хороший вопрос?
Paul, try to set your boot up sequence to your CD drive and use a Linux Live Cd to try to boot up. Let us know if that is working faster. It does sound like you have either a hard drive issue or a OS file issue.
из oldturkey03
Thank you for your reply,
I have tried all above and still will not boot. Is there anything else that I can do?
из Paul
So what happened when you booted with a different OS from the optical drive? What model Compaq do you have?
из oldturkey03
