Dom, does this look right to you:"
Intro Date: January 20, 2009 Disc Date: May 27, 2009
Order No: MB881LL/A Model No: A1181 (EMC 2300)
Subfamily: Early 2009 Model ID: MacBook5,2
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 120 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
Processors: 1 (2 Cores) Geekbench: 2719/3072*
Processor Speed: 2.0 GHz Processor Type: Core 2 Duo (P7350)
The Intel "Core 2 Duo" (P7350) 45 nm "Penryn" processor includes two independent processor "cores" on a single silicon chip.
Plenty of more details about it right here
This from the manual about your memory:" This computer comes with a minimum of 2 GB of 667 GHz Double Data Rate 2 (DDR2)Synchronous Dynamic Random-Access Memory (SDRAM) installed. It has two slots that can accept SDRAM Small Outline Dual Inline Memory Modules (SO-DIMMs). The slots are side-by-side on the logic board behind the RAM door. For best performance, memory should be installed as pairs with an equal memory card in each slot. The maximum amount of memory for this computer is 4 GB, with 2 GB DIMM installed in each slot.
Memory cards must meet these requirements:
• 1.25 inch or smaller
• 1 GB, or 2 GB
• 200-pin
• PC-5300 DDR2 667 MHz Type RAM
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
2
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
