Top of touch screen won't respond
My iPhone is sitting at the activation screen. I am able to swipe to unlock and select my country. When I press the arrow in the top right to go to the next page, it doesn't respond. I've tried pushing with some force but the touch on that specific spot does not respond. To add to further confusion I powered the phone off and swiped across the top and it registered fine. Has anyone had a similar issue and found a fix? Any help is greatly appreciated.
Это хороший вопрос?
6 Комментариев
Is it always the same area that is unresponsive?
из oldturkey03
Yes, I managed to use the zoom feature to get the arrow over to the functioning screen and to the main home screen. The whole right side is unresponsive. I cannot press any of the 4th column of apps.
из Cody
You need a new digitizer. If one part of the touch screen is unresponsive, the digitizer circuit is fractured.
из oldturkey03
I have my main phone, we'll call it main. I'm repairing one and thats the one causing the issue, let's call it fixer. I disassembled both phones and switched the screens. When I turned on the Fixer phone with my main phone screen on I had the same problem. When I turned on my main phone with the Fixer screen I was able to touch and have the right side function.
из Cody
bad touch screen IC or bad connector on logic board. Let me see what I find on the diagram.
из oldturkey03
Показать 1 больше комментариев
