Wine spill -- Laptop works but the keyboard doesn't
I spilled wine on my laptop keyboard, tried to clean up as much as I could and then let it dry for 3 days with the battery out.
As far as I can tell, everything on the laptop is working except the keyboard.
Can you tell me what I need to do to repair the broken keyboard? Do you think I need to replace the keyboard or the whole upper case?
thanks!!
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Here's a video on cleaning your keyboard. If that doesn't work you will probably have to replace it. Ralph
http://www.youtube.com/watch?v=jSpPlMdGv...
Был ли этот ответ полезен?
Оценка 3
5 Комментариев:
This one's on the MacBook Air, not sure if they are the same
из
You are correct sir--here is a new one for MacBook. Ralph
http://www.takeitapart.net/archives/MacB...
из
Here's how to install it: MacBook Pro 15" Core 2 Duo Model A1211 Keyboard Replacement
Remember to tape down the motherboard connection with electrical tape. This cable coming loose is the most common problem on this repair.
из
awesome guys! thanks so much!
из
Добавьте свой ответ
teddybaz будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 6
За всё время: 6,316
