Machine-readable instructions that direct computer processors.
184вопросов Показать все
The mail icon on my dock disappeared.
When I opened my Macbook Pro this am, the mail icon on my dock was not there. How do I get it back?
Это хороший вопрос?
Оценка 41
6 Комментариев
Thanks for your help. It was VERY easy, as you said!!!
из
I have been trying for almost an hour and cannot find my mail icon. And I have important e-mails to send on my Gmail. I am fed up with this
supposedly easy way to solve this problem irajay9@gmail.com. Two months ago in Canada, I was blocked from using my computer because Gmail would not recognize my password or the correct answers to my
identity questions.
Thanks a lot. These things should not be happening.
из
i had the same issue with my mac i got if fixed . visit https://goo.gl/efrmNz and get it fix and let me know if you need any help . thanks
из
similarly I cant find my "send an email" icon !! I am sure its easy but where?
how? thanks
из
Thank you, was painless with your help. Mike N.
из
Показать 1 больше комментариев
Добавить комментарий
8 Ответов
Выбранное решение
Very easy!
Open the Application folder and locate your Mail application you want (in case you have more than one) then select it hold your mouse button and drag it to the dock where you want it. Wait a sec so it knows that is what you want and it will place the dock alias there (won't physically move the app or alter it).
Был ли этот ответ полезен?
Оценка 30
6 Комментариев:
really is that easy - may thanks Dan.
из
So easy !!!! I feel so stupid !!! I looked everywhere but there !!! THANK YOU DON !!!!!
из
My husband was panicking as his mail icon had disappeared off his dock. ifixit to the rescue! Back to sanity. Thanks.
из
Yep, very simple fix for we the inept dinosaurs, thank you.
из
Thank you! Was having a major panic!
из
Can you find your "Applications" folder on your hard drive? If so, go in there and find the Mail application icon (Mail.app). Drag that icon to your dock. This should put it back. If you are using another mail program, drag that app instead.
Оценка 3
2 Комментариев:
where do i find the applications folder?email icon
из
Thank you so much. I needed to know the Applications folder was on my hard drive. Wish I had checked with you a few hours ago.
из
Just in case you find this thread but can't find your mail app icon, try this:
My mail icon was not in the applications folder, so I did a search on my finder. I typed in "mail" and then found all my individual email files. I still couldn't find the mail app, so I clicked on a random email file and my computer automatically opened the mail app to open the email. I then saved it to my dock again.
Оценка 2
1 Комментарий:
Good thinking ;) Thanks!
из
Periodically, when I close it, it disappears from my Dock. I just run it again, it shows up somewhere else on the dock, and I move it back.
I run it from Spotlight, but could run it from applications or on some keyboards there's a key that shows all of your apps on the screen, from which you can find mail, or type in "m" or "ma" or "mai" or "mail" to get the app.
Оценка 1
1 Комментарий:
Sounds like the drive needs some TLC. Using a bootable external drive boot up your system off of it, then run disk utility to repair permissions and the disk. Make sure you've made a backup just in case!
из
When I opened my Macbook Pro this pm, most of icon in the dock not shows the picture
but once i apply on the place . then the app will work
Оценка 1
I just had the same problem
first my doc would disappear and only show up when I had the mouse over it
I checked preferences - Automatically Hide and Show the Dock was unchecked
I checked it.. then unchecked it...
so now the dock stays visible
but Mail disappeared
I opened the program... then left clicked and said KEEP in DOCK
now it is gone again
... the Dock seems to have some new *features* hope Apple fixes them as some would call them bugs!
Оценка 1
1 Комментарий:
из
I don't know what you mean by applications folder. What do you mean by applications folder?
Оценка 1
1 Комментарий:
Think how a file cabinet works... You have your bills & letters which need to be gathered together under some method of order. Your drive is setup in the same manner. A folder is a collection of things like: applications, your written documents, pictures & videos you created or ones your family share. As well as things you buy like: music, movies & TV shows.
If you go to the dock you'll see an Icon when you pass over it were the text will tell you its 'Application' this is the application folder. When you open it you'll need to go to the bottom an click on 'Open in Finder' so you can then locate your mail program (or other application) and then drag it to the dock to make it easier to find.
из
How do I get my mail icon returned to me?
Оценка 0
1 Комментарий:
@Philauxt - Can you explain what happened. Most of the time the application icon on the dock gets lost. Is that what happened to you? Did you try searching for the app called Mail? Once you find it you can paste it back onto the dock as I explained.
из
Добавьте свой ответ
Bob W будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 14
За последние 30 дней: 64
За всё время: 69,757
