Giovanni Riva, one things to do is to replace the hard drive. If it makes a noise, then there are mechanical issues with that. Once you replace the drive, you will need to reinstall the firmware. Here is how you do that:" 1. Firmware Upgrading
A. Preparation to upgrade firmware:
1. Unzip the zip-archive file
2. Start the CD Burning software and create a new CD project (data disc) with the following settings:
File system: Joliet
Format: MODE 2: CDROM XA
Recording mode: SINGLE SESSION (TRACK-AT-ONCE), FINALIZED CD
Note: Long file name is necessary for the preparation of the upgrade disc
3. Place the content of the zip-archive into the root directory of the new CD project.
4. Burn the data onto a blank CDR or CD-RW
B. Procedure to apply the firmware upgrade:
1. Open the tray and load the Upgrade CDROM.
2. The tray closes and set will display:
“FLASH1”
3. The OSD will display
“Disc Upgrade”
“Software Upgrade Disc detected . Select OK to start upgrading or CANCEL to exit.”
4. Click on the <OK> button .
5. The OSD will display:
“Starting Software Upgrade.Please Wait.”
with the set display
“VERIFY.. WRITE…DONE
Then the OSD will display
“Disc Upgrading . Please Wait . Do not switch off the power . ”
It will do the Upgrade for the Software and OSD will show .
“Loader Software Upgrade”
and the set will show
“VERIFY”
Upgrading software. Please Wait .Do not switch off the power.”
And the set will show
“WRITE”
The whole process takes less than 6 minutes
Note: Do not press any buttons or interrupt the mains supply during the upgrading process, otherwise the set may becomes defective.
6. When the upgrade is completed the tray will open automatically and the set will display:
“Loader upgrade process has completed successfully . Press [OK] to reboot system.”
7. The tray open and the set will display:
DONE
8. Press <OK> and the tray close and the set goes to standby .
*Note : 1)The content of the HDD(i.e. the video recording(s) and/or mp3 file(s)) will not be erased
during the firmware upgrading process.
2. Preparations for new HDD
In the event when the set unable to boot up or recordings not stored due to an defective HDD, the HDD will have to be replaced with the steps describe below:
1. Replace the Faulty HDD with a new HDD.
2. Before connecting the new HDD on the Digital Board ,the jumper pin at the connector of the HDD is to be removed.
3. Connect the new HDD to the Digital Board.
4. Power up the set . It will open the tray and prompt to load the upgrading disc.(the upgrade disc is the same disc under firmware upgrading.)
5. The set will display “Load”.
6. Put the upgrade disc and close the tray and the set will show “Copy” ……… “Boot”
7. The rest of the procedure follows the software upgrade given in 1B -Procedure to apply the firmware upgrade.
*Note : 1)Do not press any button or interrupt the main supply ,otherwise the set may become defective.
2)When the HDD formatting is successful ,the set will go to standby mode.
3. Verification of Firmware
How to read out the firmware version to confirm set has been upgraded:
1. Power up the set
2. Press <setup> <3> <2> <1> in the correct sequence
3. Press <select> button
4. The TV connected to the set will display:
Product number :DVDRAAAAA
Stroke/Region Code : XX/2
Software Version :RYY.Y
Release Date:Jul 14 2006
Loader Version:51.05.2006
Build:5019V12_003 071
Developer:PHILIPS
Where AAAAA is the model number (i.e. 3450H,3460H,3470H)
Where XX is the Stroke Version and YY is the Version and Release number. that should get your HDD prepared.
Since you need your CD drive for the new HDD , I would take a good look at it. You will have to disassemble the unit and remove the drive. To do that, remove the top cover, then the four screws on each corner. Now you can check the drive, the controller board for missing or burned components as well if there is a disk in the drive. Hope this helps, good luck.
image for the jumper setting for replacement drive attached.
2 Комментариев
First tell us what machine this DVD is in.
из mayer
DVDR3460H as in the description, here ( http://www.newscenter.philips.com/pwc_nc... ) an image, (very) soon I'll post some immages without upper case.
из Giovanni
