The cause of the yellow colouration is easy. The cure is not.
The LED string at the bottom edge of the LCD is screwed to a heatsink across the width of the screen. Reflective tape is installed so as to enclose and form a light-box.
It is the reflective tape suffering discolouration where it is in close proximity to each LED, that is doing the deed.
Is it overheating of the LEDs, or is it unfit for purpose tape?
I have tried just water, then isopropyl alcohol. Neither cleared the problem.
Further to my hurried response above:
The particular Imac I'm dealing with is the mid 2010 21.5 inch model. It also suffers from the mysterious smudging too, visible at the top left part of the screen. This is an actual residue situated directly behind the LCD sandwich, which is in contact with a polarizing and diffusing series of films which are kept in register during installation.
The smudge does have a peculiar look of having been condensed on to the surface, rather than infiltrating from outside the panel.
Perhaps it is the result of the overheating of the reflective tape, vapour? and smoke? which condenses and collects at the top of the screen.
Back to the yellowing!
The LEDS are directed vertically into a plastic light-pipe/diffuser about 3mm thick, which conveys and distributes across the whole screen. The bulk of their on-axis output enters the light-pipe at low incident angles, so is relayed to the top of the screen.
The peripheral output of the LEDs suffers reflection by the yellowed tape, and thus tainted, enters the light-pipe at high incident angles, which exits to the front, at the bottom of the screen.
White LEDs are actually blue LEDs, but with a yellow phosphor/filter covering., so they do look yellow.
Был ли этот ответ полезен?
Проголосовали
Отменить
Счет
2
Отмена
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
8 Комментариев
Does anyone know what the actual issue is? What is Apple doing that is fixing them?
из Kyle Wiens
I believe that apple is working on it (they themselves still do not know) and will release a press release when they discover the problem.
из rab777hp
And to fix them Apple has just been replacing the LCDs, no idea if that's just delaying it as those themselves would then have the problem- but there's a possibility that since it only happens to some of these units, that it was just a bad batch of LCDs.
из rab777hp
I'm having the same problem with iMac 21.5 mid 2010. Have anyone found out why this problem appears? Is there any fix?
из kristijonas
I went for it and cracked the display open, found the problem and fixed it!
I've created a page about it: http://yellowtinge.jimdo.com
из uiteraard
Показать ещё 3 комментариев
