The Canon Powershot SD790 IS is a compact 10.0 megapixel digital still camera with built-in flash and a 3x Optical Zoom. It was released on March 2008.
10вопросов Показать все
camera reads, no memory card, same read with new card
how do i get the camera to recognize memory card.
to clarify, i am able to read the memory card using the computer, i can see the photos and data, and both cards work in other devices.
Это хороший вопрос?
Оценка -1
1 Комментарий
clarence, just to clarify, it does not read the cards at all? You tried the cards in another device?
из
Добавить комментарий
2 Ответов
Выбранное решение
Look inside the SD card socket in the camera (use a flashlight) and check if all the pins are OK, check for misaligned, bended or corroded pin(s). The problem could be caused by a bad contact from the SD card to the connector pins.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I followed your advice and the pins appear to be in position and normal.
из
What size SD card are you trying to use? I believe that model can't use a SD card larger than 2GB. If it's greater than 2GB, it uses a different memory format and cannot be read.
Оценка 0
2 Комментариев:
i've always used a 4GB, recently bought a 16GB and it also worked fine in the camera
из
As oldturkey03 asked, "clarence, just to clarify, it does not read the cards at all? You tried the cards in another device?"
из
Добавьте свой ответ
clarence будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 291
