White screen after case replacing. Can anyone confirm LCD is dead?
Hi,
I bought a seconds hand 3GS which had some falling damage and had to exchange the case. When replacing also saw the battery was swollen so ordered a new battery also. The flex power cable was ripped so ordered a new one also.
When everything was delivered I assembled everything and it worked like a charm. The only problem was the screen was not fitting perfectly on the top because of the sleep button holder (black plastic to which the flex cable is attached) was wrongly placed. I took everything out, reassembled the whole thing, this time fitting perfectly and powered on: black screen, fine gray vertical stripes. After a while white screen. The iphone seem to respond in itunes and i can donwload the pics from it but no image.
Took everything at least 20X apart and reassembled. Pressed connector1 firmly in the socket.
Did the reset procedure with both buttons.
Same thing. Pulling on cable 1 seem to have no effect at all (which should be the case if flex cable is damaged)
Looking at the pics can anyone confirm the LCD is dead?
Booting sequence:
1. Black screen dark gray stripes
2. White screen colored stripes
3. White screen
connectors and cables seem all ok.
Это хороший вопрос?
