The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
523вопросов Показать все
NFC: This Tag Is Not Supported
Hi, whenever I try to scan my new NFC tags that my sis got me from eBay with my S4, it says "This tag is not supported" on 3 different NFC writer apps! I even tried to scan one outside of any app with the same result! Help?
Это хороший вопрос?
Оценка 24
1 Комментарий
It works. Thanks. :)
из
Добавить комментарий
12 Ответов
Наиболее полезный ответ
Go to swipe menu you get when you swipe the home screen down ( so you can turn on bluetooth and wifi and all that) then turn off nfc tag! It stops the annoying bleeding beeping that drives you crazy everytime you move the poxy thing..................and breathe
Был ли этот ответ полезен?
Оценка 16
11 Комментариев:
Perfecto!; Mine was under settings, 'Connect and Share' NFC - swipe to off position.
из
Thanks so much for your help!
из
Thank you. I even use a galaxy S6 for this issue you solved.
из
This is about the only answer that was right
из
Thank you! You saved my life
из
Показать 6 больше комментариев
http://www.themobileindian.com/news/1186...
Samsung's flagship smartphone Galaxy S4 has been incompatible with the first generation TecTiles Near Field Communication tags. Now the company quietly plans to push the TecTiles 2 NFC Tags.
Оценка 2
1 Комментарий:
thanks it was driving me mad
из
I get the same message on my main screen when I move the phone. Please let me know what causes it and how to stop it when you know.
Оценка 2
Thank you! Thank you! Thank you! Thank you!
Was driving me loopy..
Оценка 2
Thanks for the fix too. But what is nfc tag and how did it turn itself on?
Оценка 1
How do I fix this when I need NFC on to work my smart gear Watch?
Оценка 1
Whatis NCF tag I have got
Оценка 1
i can not use this my nfc tag is not working
Оценка 0
my nfc keeps beeping on my samsung galaxy s6 keeps beeping i wanna have it on but i dont want to turn it off what can i do to make it stop beeping
Оценка 0
You can just turn off the sound. But the best way is to turn off NFC
Оценка 0
What is NFC tags and what is it used for???
Оценка 0
I had my hotel card/key in my hand and this kept beeping! I googled the code to figure-out what it was and lo-n-behold, it was the key!!
Оценка 0
Добавьте свой ответ
Jeremy Scalpello будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 16
За всё время: 85,687
