I'm having the same problem but here is what I was able to find.
Download and install this EMMC and Dummy file generator
If the EMMC gives you insane ship then you are one of the unlucky people like me. Try then the dummy file application, some people reported it helped.
To be honest, I feel it's a temporarily solution. It seems that Samsung doesn't use Good quality components. I've tried stock ROM and everything out so far the alliance-rom.com is the best stable one with me. After the installation you might try to install the Perseus kernal. Mine is better than before.
Good luck,
Zak
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
4
13 Комментариев
What's wrong with it?
из oldturkey03
Is the phone "locked" to a UK provider?
из Richdave
The phone is not locked to a UK Provider it is a gsm factory unlocked phone.
The phone will not turn on, when pressing the power button only a red flash by the proximity sensor. I've tried a friends battery in my phone and did not work placed my battery in his and it did. So it's not a battery/ charging issue.
из Skyler Robinson
So they had no luck on fixing my issue, but they are sending me back my phone and refunding everything but $15 from what i paid. next step will be taking it apart and replacing some of the phone and hopefully that works.
из Skyler Robinson
So what happenned, did they fix your phone? What was the solution, did they change the insane chip?
из Erhan Muco
Показать 8 больше комментариев
