Can I use a 35/4uF instead of a 4/35uF Sh capacitor
my air conditioner needs a new sh start motor capacitor.
the original that needs to be replaced is a 4/35uF... and the one I was sent is a 35/4uF...
the numbers are inverted...voltage the same as all other infos, but before i go and connect it i wanna make sure it works...
any technicians perhaps here with an idea?
__EDIT____
Here are some pics added after as requested:
1-in order going down:broken Capacitor (taller one)
2-New Capacitor (shorter)
3-last pic is to show there's one taller than the other, the old one broken being the taller one
4-Old top
5-New top
Это хороший вопрос?
3 Комментариев
I am pretty sure this is a run cap and not a start cap. Start caps are higher microfarads and are black plastic.
из hvacjack
Looks like the same capacitor, just written in a different order. A 4/35 µF capacitor usually means 4 µF capacitance rated for 35 V, and some manufacturers simply print it as 35/4 µF on the label.
The important thing is that the capacitance (4 µF) and the voltage rating (35 V or higher) match the original specs. If those values are the same and the terminals match your wiring, it should work fine.
из Sarah Wilson
@sarahwilso35724 that is actually incorrect. Those are two capacitors in one can. One is a 35µF and the other one is a 4µF. Both capacitors are rated for 270VAC not 35V
из oldturkey03
