Engine over heats at idle
the engine overheats at idle, but cools down when the car is moving, what's wrong
Это хороший вопрос?
Это хороший вопрос?
Jason Dixon, there are multiple things that can cause this. First check to make sure that you have enough antifreeze in your vehicle. Then make sure that your belts are tight enough and not sleeping. After that make sure that your fans are coming on, and check your radiator for any obstruction. Clean it by flushing it from the backside with a water hose. Of course there is also a possibility of a stuck thermostat Hope this helps, good luck.
Был ли этот ответ полезен?
I've dun the cap ! I've dun the thermostat ! I've dun the circulation ! I am only gits hot when in park Or drive idling setting still gets hot this is a 2005 Dodge grand Caravan 3.8 L motor anybody got any ideas
Checked your fan? Possibly water pump....
Anybody got any ideas
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 17
За всё время: 2,781
