Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1972вопросов Показать все
iPhone 3GS won't boot at all
My iPhone 3GS won't boot at all. I bought it off of ebay, and it was listed as water damaged. Only the water indicator in the dock connector was active, but the other one at that top of the phone was not active.
I took the phone apart, soaked it in alcohol, gently cleaned it with a toothbrush, and finished it off with CRC electrical contact cleaner. I even removed the logic board shielding during this procedure.
If there's a simple cable I can replace to get it working, I'd be happy to do so. The one cable coming out of the display that doesn't "click" in seems to be burned, or something like that. I've attached photos for reference.
I cleaned up the copper side of the cable, but the back side that appears to have a black dot - I can't clean that side. What cable is this, and is it causing my problems?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
I would try a dock connector seems like the battery's flat and the docks broke
Был ли этот ответ полезен?
Оценка 1
Комментарии:
Is there any way to repair the dock connector, rather than getting a new one? I already cleaned a good bit of gunk out of it, and it looks really clean at this point.
из
If the parts not going buy a replacement part it's so cheap
из
Добавьте свой ответ
Casey Friday будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 298
