iMac G5 will not boot up.
My iMac will not boot up. No sound or anything.
Это хороший вопрос?
Это хороший вопрос?
First step would be to unplug/replug and check another appliance in the same power plug. If still having problems try listening closely when attempting to start up. Even though there is no beep it could be starting, listen for the gush of a fan or the spinning of a hard drive. If still nothing it is likely 1 of 2 things: mother board, or power supply. In this iMac I would guess it is the power supply.
Был ли этот ответ полезен?
This unit has a history of bad capacitors. Ralph
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 3,713
3 Комментариев
i have the same problem, it turns on, and stays in the blank screen with the apple and the loading circle, after a dew minutes the fans spin faster and it shuts down after that. any ideas please
из Anthony Perales
I GOT A iMac G5 17" Model A1058 AND EVERY TIME I TURN IT ON IT THE BLANK SCREEN AND WITH THE APPLE IMAGE AND THE LOADING CIRCLE COME ON AND AFTER THAT IT WONT GO TO MY DESKTOP AND SHUTS DOWN AFTER 5 MINUTES IS THEIR ANY WAY I CAN FIX IT???
из jesse
Please cut and paste this into a new question. These problems are entirely different. I'll give you the solution then.
из mayer
