The Motorola Xoom is an Android-based tablet computer by Motorola, introduced at CES 2011 on January 5, 2011. It is the first tablet to run Android 3.0 Honeycomb.
43вопросов Показать все
Lost power won't power up
I accidentally plugged a phone charger in one of the other ports. When I did screen went black. No it's not powering up. The battery indicator led lights white then turns green. But will not turn on at all. I hope it can be fixed.
Thank you
Lee
Это хороший вопрос?
Оценка -1
Добавить комментарий
3 Ответов
Try to reset the device? vol up + power.
If it does not work you might need to open the device up and see whats damaged.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Thank you I tried the volume up and power button. No go.
из
Thanks it worked on mine.
Оценка 0
Thanks so much! Worked on mine as well.
Оценка 0
Добавьте свой ответ
Lee будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 681
