How to remove front bezel from rear panel
Hi together,
is it possible to remove the front bezel from the rear panel and how can I do this?
Thank you in advance.
Best regards Lance
Это хороший вопрос?
Hi together,
Best regards Lance
Это хороший вопрос?
If it were possible it would likely require that you follow this guide then use a heat gun to melt the glue holding the bezel to the plastic case. Be careful no to melt the case. If that doesn't work it likely isn't possible. There is no iFixit guide for doing it, which tells you something.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,848
