1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192вопросов Показать все
Why is battery capacity not replaced?
Hello,
I just followed your guide to replace the battery. After looking in the system report I saw that the loading cycles are reset but not the capacity. Its still the number from the old battery. After charging until 100 % in charge remaining there was the same number as in full charge capacity. When taking out the magSafe the percentage immediately jumped down to 85 %.
I tried SMC reset already.
What can I do to see 4680 mAh written in in "Full Charge Capacity"?
Thanks in advance..
Это хороший вопрос?
Оценка -1
1 Комментарий
I also change my battery in my Iphone 4, and I have the same issu about the new one, nothing change and when I connect the iphone for the first charge it show the percentage as the old one.
из
Добавить комментарий
1 ответ
Выбранное решение
Download and run Coconut Battery to see if you get the same information: http://www.coconut-flavour.com
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I did. Same stuff. I start to believe that the battery might be junk :(
из
Добавьте свой ответ
Dominik Schroeck будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 311
