Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2375вопросов Показать все
iPhone doesn´t charge even after repair it
My iphone 4 was charging very slow (10% by hour) and it didn't detect that its plugged, so I thought "May be the battery was dead", so I replace it and it didn't change. After that I decided that the dock connector is the problem, so i replaced it but the problem persist.
Maybe something on the logic board is damaged?
Это хороший вопрос?
Оценка -1
3 Комментариев
Like Vincent Monteil says, try a different cable as well as an AC adapter and see if that makes a difference.
из
I've tried with lots of cables even with a 30-pin to RCA and it doesn't stream video or audio
из
Have you checked the charging coil and components?
из
Добавить комментарий
1 ответ
Выбранное решение
Hi jim !
In fact, people often think that the problem comes from a dysfunctional iPhone part. Actually, the problem could absolutely be your connexion cable or AC Adapter ! Do you use an official one ? Is it old ? I know that it can seem to be nothing but even if they are more expensive, you shall prefer using official new one. Your iPhone is mabe ok !
Let us know how it goes,
Hoping to have helped you,
Vincent
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
jimenezser будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 192
