oil change says -20%
my daughter is traveling her Honda just went to -20% for oil change will it be ok. for another 100 miles till she gets home?
Это хороший вопрос?
Это хороший вопрос?
ashley, yes she absolutely will be okay. The oil change intervals are not that crucial as long as the oil does get changed eventually. Hope this helps good luck.
Был ли этот ответ полезен?
She will be fine. If it is synthetic oil it can sometimes last a couple thousand miles more than the average change, however make sure to replace the oil filter as well at least every couple oil changes and reset the diagnostic information right after you change the oil/filter otherwise it will still say ~20%. Keep in mind, when it says 20 % it can be anywhere between 20 and 11 % if I recall from the owner's manual. Hope this helps :) I have the same car.
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 22
За всё время: 1,851
