How to get WIFI and Bluetooth drivers for dell N5010?
I need the wifi and bluetooth drivers of the dells as i can't get them in any site ....plz any one can help me for finding this.....
Это хороший вопрос?
Это хороший вопрос?
First you have to know which wifi card is installed on your device but i link you all possible drivers.
Go to this site and click in the menu Drivers&Downloads there you can find all drivers.
Был ли этот ответ полезен?
Apparently seems like your W-LAN card is either disabled from your network connections or may be there is some hard switch which turned off. All you need to go open network and sharing center then click view network connection to make sure that you Wireless connection is not disabled in any case it should have to be enabled.
Other way is to check on your keyboard from top F1 to F12 keys if you can see a Antenna sign on any of key then press that key by pressing Fn key together.
If the problem still persist then I would recommend you to go on your manufacturer`s website to download the latest driver and update your driver. Good Luck
Thank you very much/ my laptop is i5 Aspiron N5010-window 7 64 bets
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 20,577
1 Комментарий
just visit dell site to download the driver visit https://goo.gl/SSBGrW
из ark kasey
